[email protected]
I began wondering if air flight could ever use electric motors
to drive turbines that would provide equivalent thrust of jet turbine engines
Yes, it can!
But only with the use of fuel.
What has been patented already is the MHD generation of power at efficiency
much greater than turbine power extraction efficiency from a high temperature
(enough to melt a turbine), high pressure, high "enthalpy" gas stream, and the
use of that power to drive a conventional compressor turbine at conventional
electric motor efficiencies in the 90s of percent, with the compressed air
gaining energy from the burning of fuel.
The combination of ultracapacitors and electric fan drive has enough power to
sustain flight for seconds. Batteries, not enough power, and electrolytic
capacitors, insignificant flight time (energy).
Sorry, you can barely drive on stored electrical energy, much less fly. To go
man go, you need fuel, whether it's Gatorade or JP4, because the freely
available energy of oxygen in the air is essentially unlimited.
That's why fuel cell vehicles are promising. Good energy per weight fuel, nice
power per weight reactor.
I can put some PC 2500 ultracaps on ebay if you'd like to tinker with this a
bit. Hazmat: contains methyl cyanide, hermetically sealed. On overcharge,
venting may occur with release of methyl cyanide, and cyanosis. Cyanosis can
result in death.
Reserve price: $70 each.
Yours,
Doug Goncz ( ftp://users.aol.com/DGoncz/ )
Read about my physics project at NVCC:
http://groups.google.com/groups?q=dgoncz&scoring=d plus
"bicycle", "fluorescent", "inverter", "flywheel", "ultracapacitor", etc.
in the search box
