Stoopalini
- Nov 30, 2011
- 8
- Joined
- Nov 30, 2011
- Messages
- 8
I have a Denon AVR-987 receiver, which has been great for the past 4 years, but has recently started giving me problems.
At 1st, I would hear a 'click', and the sound would go out. This is with the speakers connected to the internal amps (via binding posts). I would turn the unit off, then back on, and the sound would return.
Then, the same thing happened, but in addition the HDMI video stopped being passed as well. A reset by powering on/off did not fix it either. I tried the CPU reset (holding buttons while cycling power), and it didn't help. All other functions seem to work (display, input select, etc ...). Even when I selected the 'Tuner' input I still received no sound. Also, interestingly, during this troubleshooting, I noticed the volume knob no longer changed the dB readout on the display.
So I removed the unit from my entertainment center, and about a week later, looked inside and found nothing obvious. I hooked it up in my office to test it out and it started working fine again.
So I reinstalled it in my entertainment center, but used external amps with the pre-outs thinking maybe the internal amps were causing too much heat. This worked for about 2 weeks, but now the original problems have resurfaced (Audio 1st, then both audio & video), even with no speakers connected to the binding posts.
I am decent with a soldering iron, and have the tools, but no idea where to start. I called a repair facility, but they charge $69 just to diagnose and stated it will probably be no less than $200 to repair.
Is there a way to permanently disable the internal amps? Can I just remove the speaker protect fuses to do this, or will that also disable the pre-out circuitry as well?
Any common issues with this type of receiver I can check for?
Thanks for any assistance!
Thomas.
Thomas.
