73's de Edd
- Aug 21, 2015
- 3,629
- Joined
- Aug 21, 2015
- Messages
- 3,629
CONDITIONS:
With an unpowered set, and with your DVM being in its DIODE test mode:
Q151: I am not getting a dead short between base and emitter but DMM does not show 0L but 1681
That range of 1681 is exactly what I would expect a good transistor to read.
CONDITIONS:
Now you must have powered the unit up and then found :
Q151:
DMM set to 200mV
Emitter: 0.3mV
Base: 8mV
Collector: 0.3mV
Those Q151 collector and base voltages are vewy-vewy FEEBLE.
Any chance of spot checking back at RED 3 and confirming its 5.6 VDC presence and then short
across Q151' s R159 base resistor and see if the voltage at Q151 collector then shoots on up towards that 5.6 VDC supply level .
CONDITIONS:
Q151:
DMM set to 200mV
Emitter: 0.3mV
Base: 8mV
Collector: 0.3mV
