Sir bushtech . . . . . . .
now . . . .Dave . . . . . he sez . . . . .
you may have accidentally shorted something out with the tip of the meter probe
Which directly relates to . . . . . " der bushmeister " . . . . . and his meter probes experiences / fallacies/ woes and OUR related " The Great Polyester Capacitor Debacle and Escapades Extraordinaire of 2016. "
That is SPECIFICALLY why I remoted the UBER-CLOSE proximity test points measurements of that u/p chip, so as to be far-far away from it . . . . by my specifying two common alternate connections .
CURRENT SITUATION:
Until available, you can work around the demise of that that ICP-15 circuit protector . . . . .rated 600 ma - 50V . . . . . with a standard blow 1/2 A fuse.
Those posted schematic clips were absolutely too skimpy on pixel density.
The relevant expected work areas to be encompassed are condensed within the very bottom illustration .
It is being of low enough composed density so as to be free hosted, but if it is kicked into 2 x mag . . . all of its info is then being very easily readable.
Additionally, earlier, there was one worry and some extended conversation about the units u/p condition, and the havoc that a bad u/p could wreak.
That one voltage measurement given, tells me that the unit is still alive, knows its job, what day of the week it is and where it is and that it was even trying to respond to your prior given command of turning on the unit.
BUT . . . .alas . . . . .that forthcoming logic high output is and was being overridden by a default condition that was detected in the system by a feedback loop to the u/p unit.
PRIMARY INTEREST IS INITIALLY TO DESIGNATED SECTION . . . . . . in GREEN CIRCLE A . . . . .
I am requesting about every conceivable voltage and current loop encompassed, within these 12 RED RECTANGLE voltage. test points, to be used for our analysis.
Measure them as soon as the standby/sub power supply is again outputting DC voltage at test point 2 on, as I suspicion all is now still being well at test point 1.
TECHNO REFERENCING:
73's de Edd
