A
[email protected]
Okay. This should be simple. I have been designing circuits for years
but I have never had a satisfactory understanding of this:
I have a circuit. Its +5V connected to one end of a resistor, the other
end of the resistor is connected to the anode of a diode, the cathode
of the diode is connected to ground.
I also have a graph showing diode current versus diode forward voltage.
So my question is, if I pick some arbitrary value for the resistor, how
do I determine exactly how much current will be flowing through the
diode using the graph?
Yes I know you can predict it roughly by using the nominal diode
forward voltage (i.e. 0.6V) and then calculating the resultant voltage
drop across the resistor and therefore the current through the resistor
and thus the diode, but thats very imprecise and not what I am trying
to do here. I want to be able to predict the diode current for all
kinds of values of resistors, not just values which result in a diode
forward voltage in the vicinity of the knee.
Please help me!
Thanks!
Asa
Please help me!
Thanks!
Asa
