DC Motors and speed control
Status
Not open for further replies.
well-known_reindeer
Aug 15, 2022
Aug 15, 2022
I have a 24 volt 350 watt scooter motor that need rewound. Specs say 3000rpm. Doe anyone know how many turns this motor would be?
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
The procedure when re-winding a motor is the count turns of each winding removed.
Probably not worth the effort for a small motor such as that, in light of motor replacement costs .
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
So you need a larger motor, rewinding is not going to achieve it!
Alec_t
Jul 7, 2015
3,591
Jul 7, 2015
3,591
Agreed. For a given Wattage motor there is a trade-off. You can only increase torque at the expense of rpm.
For any given motor there is a fixed space for the windings. Torque is proportional to the product of coil current and number of coil turns. So increasing the number of turns means using thinner wire to fit them into the space. But thinner wire necessitates lower current.
CircutScoper
Mar 29, 2022
300
Mar 29, 2022
300
May I call you Rudolf?
As has already been said, Rudy, basic physics dictates a fundamental tradeoff for any given power rating between rpm and torque. Your 350W motor rating is equivalent to roughly 1/2 horsepower (actually 0.47). At 3000rpm, that works out to ~1.6 foot-pounds of torque. The only way to get more torque from 0.47hp is to reduce speed, and even if a slower scooter would be acceptable, you can't achieve that from rewinding alone.
Have you looked into changing the gearing ratio?
CircutScoper
Mar 29, 2022
300
Mar 29, 2022
300
That too has the torque/speed trade-off.
Of course. As said Torque = Power / Speed. At constant Power, Torque can only increase at the expense of reduced Speed.
The advantage of doing it by lowering the gear ratio is that it might be possible without re-engineering the whole powerplant.
CircutScoper
Mar 29, 2022
300
Mar 29, 2022
300
On second thought, maybe best to forget the whole thing, given as little as we know about the "scooter" in question.
If Rudy WERE successful increasing motor torque, maybe that would cause the gears to strip, wheels to skid, or his antlers to fall off!
Status
