speed control of 2 x 110v 2kw angle grinder motors
Discussion in 'Sensors and Actuators' started by SteveMR, Jan 22, 2013.
  1. SteveMR
    SteveMR
    Jan 22, 2013
    As the title states I would like to control the speed of 2 x 110v 2kw angle grinder motors.
    I would like 5 speed settings and is there a simple solution to this I could build as a beginner?
    Cheers,
    Steve
  2. poor mystic
    poor mystic
    1,074
    33
    Apr 8, 2011
    In electric motors the current is partly controlled bt he resistance of the motor windings and partly by the inductive reactance of the windings. So although reducing the frequency of the AC supply does also lower the speed of the motor it also allows greater currents to flow - the motor becomes more and more like a short circuit as frequency is reduced. At low supply frequencies there can be large currents flowing, which are likely to damage the motor.
    When supply frequency is increased, less power is available.
  3. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    You could try a lamp dimmer circuit, this consists of a resistor, capacitor,diac and triac. A normal lamp dimmer will not be powerful enough so you will need a bigger triac. This will adjust the speed but will not control it with varying loads.
