Hello. I have a problem with electronics for controlling the actuator... So, this actuator has 2 limit switches, for open and close. Everything works on 12VDC. When you try to open and close actuator when it reaches the limit switches the motor stops momentarily... But somethimes when actuator touches the limit switch it doesn't stop momentarily like it's supposed to, instead it looks like that it is got some kind of inetria left in it, and it proceeds for maybe one or two milimetars. It's is not a big move, it took me some time to notice it in the first place. The problem is that this electronic board is got some kind of protection, so when that happens it goes into error and you can not move the actuator anymore unless you restart it (turn it off and on again)... It doesn't happen often, maybe one or two times per 50, but i want to solve that problem... What can be the reason? Can someone explain to me what is this yellow thing that is connected to COMMON contacts of the relay and what is its purpose?
https://postimg.org/gallery/1iwon2124/
Thanks everyone, looking forward to yours answers!
