DC/AC inverter
Discussion in 'Electronic Basics' started by Bandu, Mar 15, 2007.
  1. Bandu
    Bandu Guest
    Is there any DC/AC inverter method that do not use big step up
    transformer?
    Regards,
  2. Sure, if Vout < Vin. OK, you can do a step-up inverter if you play games
    with switched capacitors, but for more than a watt or two, the transformer
    is probably cheaper if you want standard powerline frequencies.
  3. There are designs that step the voltage up at high
    frequency, so that a smaller transformer will carry the
    power, then that high frequency is rectified to DC and re
    inverted to a low frequency output, with no voltage change,
    so no transformer.
  4. Bandu
    Bandu Guest
    thanks John.. do you know what is that method called? boost-buck ?
  5. Sorry, I don't know the technical terminology for this
    configuration.
  6. MassiveProng
    MassiveProng Guest
    Damn! You almost got it set correctly!
    Do you have an obsession with seeing your posts at the top of a new
    header pull or something?
  7. Lionel
    Lionel Guest
    'boost'
