Hello to all,
I have one fuse dimensions 5mmx20mm blown in a power supply unit. It is written on it: T8A 250V. Since I don't have exact to replace it, I wonder could I connect two fuses with same dimensions but 4A 250V in parallel?
I was thinking to place one fuse in the holder and another one just to solder on the top. Since both fuses are identical characteristic I think there will not be a problem.
Is there some potential problems that I can expect?
Thank you
Thank you
