Coil Question
Status
Not open for further replies.
GimmieFuzz79
Jun 24, 2017
8
Jun 24, 2017
8
Hello All,
Long time reader, first time caller and I come bearing a not so easy question...
I have recently inherited a machine capable of winding coils. Figuring it may be time for a hobby, I decided I'd give building my own set of single coils a shot. Here's the problem I keep running into: With the examples I have (from my own vintage sets to modern replacements) there is very little to no evidence in support of readily available techniques. In short, lots of misinformation in a burlap sack steeped in non-GMO, gluten-free, free range herbal snake oil tea. Also available in decaf.
Due to this revelation I began looking elsewhere. After weeks of studies in other coiled constructs, I can see there is a procedure with steps but no help in applying said procedures and steps. Would anyone happen to have some information they could point me towards or suggestions for application?
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
What level are you looking for? A design from the ground up, or reviving the present machine system?.
M.
GimmieFuzz79
Jun 24, 2017
8
Jun 24, 2017
8
Minder,
If you mean level of expertise than beginner but have handled the materials plenty. The design is from the ground up but from all I've seen it reads something closer to procedural. As for "reviving the present machine system"...you have me a bit lost there. Please explain?
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
You say you have a machine capable of it, is it set up for winding now or are you thinking of designing a new system entirely?
M.
GimmieFuzz79
Jun 24, 2017
8
Jun 24, 2017
8
M.
The machine is up and running well. A few testers have been made and though functional they aren't exactly efficient. Currently decoding Dukes suggestion (Thanks again!) and will give that a shot shortly. Using a coil estimator has given me some idea towards a direction but the ratio seems a bit high at the moment.
Thank you for your help Minder!
I am having a lot of trouble understanding what you are asking about.
You say you have "made some testers." I assume this means you have wound some coils using the machine. You say they are functional, but not efficient. What does "efficient" mean here? What is it you are trying to improve?
GimmieFuzz79
Jun 24, 2017
8
Jun 24, 2017
8
Hello Bob,
Part of the issue on my side is being able to communicate the issues correctly. Yes, I've built several sets and they were fun to create but now I would like to build something that functions correctly. That being said, errors in a traditional build would be far easier to correct than just "Spreadin' it on there like a Son-of-a-Litz!"
Thank you Bob
Hello Bob,
That is for sure!
sets of what?
In what way are they functioning incorrectly? It is hard to imagine a coil that is functioning incorrectly. Perhaps the inductance is wrong, or the resistance is too high, but what do you mean by functioning incorrectly?
Thank you Bob
GimmieFuzz79
Jun 24, 2017
8
Jun 24, 2017
8
Bob,
Thank you for your time and understanding on this one Bob as I'm still learning how to ask the right questions correctly.
One option would be to tell us what the thing which uses the coils is, what it is supposed to do, and then how it comes up short with your coils.
For example:. The finite improbability generator is supposed to create finite amounts of improbability, but with these coils all I get is average probability, no matter how effective the entropy source is.
GimmieFuzz79
Jun 24, 2017
8
Jun 24, 2017
8
Hello Steve and Thank you.
These are guitar pickups.
Ok, so what should they be doing, and what are they doing?
GimmieFuzz79
Jun 24, 2017
8
Jun 24, 2017
8
Therein lies the problem: If I had built something following a roughly set procedure then any misstep could be corrected. Since I followed the readily available, modern "applied at random" style of winding techniques it's harder to judge the performance due to it's case by case nature and the fact that it has been built "at random." Then this also becomes an issue of personal taste and before that rabbit hole is breached; these responses have given me some new areas to try.
Thank you for your patience and more informed questions will be asked shortly.
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
Can you post any pic of the existing machine and/or its operation?
M.
If you can't identify a difference in behavior between a working unit and your unit then there's not much we can do.
14,265
14,265
agreed
I'm closing this thread because it has staggered all over the place like a drunk on his way home from the pub
and neither are going anywhere productive
@GimmieFuzz79
you are welcome to start a new thread BUT state clearly in the opening post exactly what you are doing, what you are trying to achieve
any photos of your "coil" constructions etc
Give us ALL the information so that we can better answer any questions you may ask
Status
