Cleaning Scanner Glass (Inside) hp3970
Discussion in 'Electronic Design' started by Jim Thompson, May 31, 2007.
  1. Jim Thompson
    Jim Thompson Guest
    Anyone know how to dismantle and clean an hp3970?
    I've developed a foggy looking coating on the _inside_ :-(
    ...Jim Thompson
  2. Meat Plow
    Meat Plow Guest
    Cigarette smoke.
    #1 Offishul Ruiner of Usenet, March 2007
    #1 Usenet Asshole, March 2007
    #1 Bartlo Pset, March 13-24 2007
    #10 Most hated Usenetizen of all time
    #8 AUK Hate Machine Cog
    Pierre Salinger Memorial Hook, Line & Sinker, June 2004
    COOSN-266-06-25794
  3. OK thats you but how about the scanner?
  4. What have you been scanning that's steaming up the window?
    Best regards,
    Spehro Pefhany
  5. JackShephard
    JackShephard Guest
    Most well designed scanners have a method to address just this need.
    You should be able to DL the manual from the HP site as well.
    It should even appear intuitive. Well.... to some... ;-]
    Usually, one of the ends has a cap that comes off, like the paper stop
    end after removing part of the scanner apron or such.
  6. Meat Plow
    Meat Plow Guest
    Just shut the **** up prong.
    COOSN-266-06-25794
  7. JackShephard
    JackShephard Guest
    Jeez. Three responses from three "folks" and not one actually helped.
  8. Meat Plow
    Meat Plow Guest
    Four including you, prongfuck.
    COOSN-266-06-25794
  9. The P.I.'s reports on 'Flat Bastard'?
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  10. JackShephard
    JackShephard Guest
    Still the perpetual, immature retard, you are.
  11. Its SO hard for you to come up with new lines with only half a neuron
    firing, isn't it, bitch.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  12. Jim Thompson
    Jim Thompson Guest
    Michael, Why don't you cross-post all your responses to jerks, such as
    Shephard, to something like "alt.ima-fucking-jerk", so we can filter
    it all out ?:)
    ...Jim Thompson
  13. Ok, if you'll post all your "Weather in Arizona" stuff somewhere
    else. I can't afford to keep a dog, and you have to admit that ol' Jack
    comes a' running everytime I call him. I shoud say, As long as h
    doesn't step on his tounge and trips.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  14. Jim Thompson
    Jim Thompson Guest
    Damn!! You made me spew my coffee again ;-)
    ...Jim Thompson
  15. What can I say? My health is slowly improving after the surgery, and
    so is my timing! When are you going to learn to throw a clear drop
    cloth over your monitor and keyboard before reading ANY of my posts? ;-)
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  16. Jim Thompson
    Jim Thompson Guest
    My BAD ;-)
    I am extremely happy that your health is improving!
    ...Jim Thompson
  17. Jim Thompson
    Jim Thompson Guest
    All I find on the absolutely worthless hp site is instructions to
    disconnect power before wiping the outer surface of the glass ;-)
    ...Jim Thompson
  18. Thanks. me too! :)
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  19. Jim Thompson
    Jim Thompson Guest
    I will ;-)
    ...Jim Thompson
  20. The manual says:
    For instructions on cleaning the underside of the scanner glass, go to
    www.hp.com/support, select your country or region, navigate to the
    support page for your scanner, then click the link to view information
    about cleaning the underside of the glass.
    So they at least promise to supply the information, and a support
    request might be honored.
    Here's info from a different HP scanner:
    If the 6200C is like the 6100C, which is mechanically similar
    to my 4C ...
    0. Disconnect power. Take anti-static precautions.
    1. Remove the auto-feed assembly.
    This should expose the rear Torx screwheads.
    2. Remove the metal covers over the 2 front Torx screw heads.
    3. Remove the screws and lift off the upper case w/glass.
    4. Clean and replace.
    Search the net for further platen glass cleaning advice.
