N
N Cook
I know this is just a pc ps but I'd like to understand what is going on, or
not going on, even if not repaird.
There are 3 HF transformers and an opto-isolator bridging the HV and LV
sides.
The startup oscillator, on the HV side, is a KA1H0165R whose o/p crosses the
divide to give a Vcc of 12V on the main SMPS controller a KA3511DS, both
datasheets downloaded.
This controller o/p should then cross the divide to drive the HV side main
oscillator to drive the main transformer back to the LV side supply rails.
The SMPS "flag" output pin goes high meaning no-function and no o/p pulses
for either push-pull output of this KA3511.
As the KA3511 monitors over-voltage, and more to this point, under-voltage
of the supply rails , how should it ever get started if it never outputs any
main drive pulses, so no main supply rails.
If i find time today I will run the KA3511 from 12V bench supply and see
what happens .
sides.
what happens .
