Can You Paint a Circuit Board?
New2Electronics
Mar 13, 2016
24
Mar 13, 2016
24
I want to paint my circuit boards (after they have been built) and add liquid tape to the bottom of the board where the parts are solder together. Is there a downside to this, possibly with heat or some other issues?
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
This is typically done with Conformal Coating, or Glyptal aerosol, although they can be had in a small can also.
M.
davenn
14,265
14,265
shouldn't be a problem ... use lead free enamel paint
many commercial PCB's are dipped in varnish type material so at least the components are still visible
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
Depending on the components, some coating compounds should be avoided!
Mainly anything that changes sizes as it cures or hardens... it can dislodge components and wreak havoc on the board...
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
It's also advisable to bake the PCBs in the oven to remove any moisture before coating. Not sure on the temp needed so you may want to have a quick look.
Adam
