Building Preamp from kit but a resistor keeps burning up
Jumpybuns
Mar 29, 2015
12
Mar 29, 2015
12
I purchased a preamp kit from classic api, the vp26. It should be no problem but everytime I plug the completed circuit into the lunchbox, A 200ohm resistor starts to smoke. Everything seems to measure as normal and im out of ideas.
Thanks for your time!
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Can you post the schematic, indicate the 200 ohm resistor in question and also post photos of both sides of your board indicating again, the 200 ohm resistor in question?
Jumpybuns
Mar 29, 2015
12
Mar 29, 2015
12
Here's a link to all the docs I was given.
The problem resistor is R6. I left the 2nd burned one on there so you can see what kind of condition its in!
Thanks a bunch!
[Mod edit - deleted a risky site addy]
brevor
Apr 9, 2013
87
Apr 9, 2013
87
I cant find the burned resistor in the photo, check for solder shorts around the resistors pads. Also make sure C9 is not in backwards.
davenn
14,268
14,268
agree with brevor .... what is cooking ? Steve did ask you to indicate which component it was
R6 ?? which one is that ?
Jumpybuns
Mar 29, 2015
12
Mar 29, 2015
12
It's the one at the top
Sorry about that
davenn
14,268
14,268
OK
one side goes to that electro cap above it make sure that that cap ( and the other 2 electros below it) are in the circuit the right way around
I cannot make out where the other side goes to
BTW it looks like one solder joint on that T1 transformer isn't soldered correctly
what do those 3 switches in the middle do ?
I didn't want to risk opening that zip file form some unknown site .... what was in the zip file, can you post it directly to the forum ?
Jumpybuns
Mar 29, 2015
12
Mar 29, 2015
12
i cant tell where it terminates either, it looks like right there. meaning one side goes to that cap and the other doesnt go anywhere
ill touch up that T1 for sure!
im self taught so thanks for going easy on me!
the 3 middle switches are a mute, phase, and pad
  • 4_Classic VP26 Rev B schematic.pdf
Jumpybuns
Mar 29, 2015
12
Mar 29, 2015
12
that website is pretty cool if youre into music stuff. good price on the DIY op amps.
(*steve*)
25,510
25,510
A short across C9 or C9 connected around the wrong way would be most likely.
Given what I can see of your soldering, if I were you, I'd get a little practice soldering and re-solder pretty much every joint on the board.
It appears that the components go through plated-through holes. If the joints were soldered properly you would be able to see solder filling the holes from the top side of the board (it would be almost level with the top of the board). I don't think I can see even one example of that.
Jumpybuns
Mar 29, 2015
12
Mar 29, 2015
12
So I should get a new cap for c9?
Will re-soldering everything help solve my issue? I know I need practice but I'm afraid of beating up the pcb
davenn
14,268
14,268
OK so SW1 is supplying 48V phantom power to In-Lo and In-Hi inputs via R6 200 Ohms
R7, R8 and SW2
wouldn't hurt to replace C9
But initially leave it out and see if the resistor still smokes, if so the fault lies elsewhere
make sure there is no short cct between either J1-8 or J1-10 to ground (0V) rail
Jumpybuns
Mar 29, 2015
12
Mar 29, 2015
12
Ok, I resolderd this section of the board. Still smoke.
I replaced C9, still smoke.
I removed C9. No smoke.
About to test for a short but Ive never done so Take my results with a grain of salt
brevor
Apr 9, 2013
87
Apr 9, 2013
87
So you tried a new C9 and it still smokes, but if you leave C9 out it doesn't smoke. Thats very strange ! Are you sure the 48 Volt source you are using is OK?
davenn
14,268
14,268
OK that is a major hint
Again ... are you absolutely sure you are putting C9 in with the correct polarity ?
I suspect not
davenn
14,268
14,268
From the photos and drawings he posted it appears to be correct.
I cannot see any marking on the PCB to indicate which way around all those electros are supposed to go
There probably is a marking on the board under the cap
(*steve*)
25,510
25,510
Did you use a new capacitor and resistor when you did your replacement above? Can you show us a closeup of the soldering of the capacitor? Have you measured the resistance across the capacitor?
Jumpybuns
Mar 29, 2015
12
Mar 29, 2015
12
yep, new caps new resistors. ill measure the resistance tonight, i havent done that with new cap
heres a pic of the solder of the cap, its dead center (the 2 vertical points)
