What you want is a hydrophonehttp://en.wikipedia.org/wiki/Hydrophone
You should do a bit more research before start this project. For
practical audio frequencies, the attenuation of air is uniform with
frequency. My recollection is water falls off at either 6dB or 12 dB
per octave. So the loss at 24KHz will be severe.- Hide quoted text -
- Show quoted text -
Dear M...
I already have a hydrophone. That is what I am going to use to receive
the 24khz. It will receive or transmit up to 25khz, the mfr says to
stay away from 25khz if transmitting, but I can receive at any
frequency within its range with no problem. Been there, done that.
As far as research, you might want to do a little yourself, start
here:
http://www.massa.com/fundamentals.htm
The what you call 'loss' is proportional to 1/r^2, just like em waves.
Because of the spherical or hemispherical nature of the wave
propagating thru the water. There are also absorption losses due to
the manganese dioxide present in sea water. At 20khz, this amounts to
-3dB in a kiloyard (I know, unfortunately some folks still use the
imperial system). Now the 1/r^2 I am speaking of is the acoustic
energy flux density (aka intensity), NOT the sound pressure level. The
sound pressure level falls off as proportional to 1/r. I would refer
you to a great book on this very subject:
"Principles of Underwater Sound" by Robert Urick <sp>, and also
"Transducers and Arrays for Underwater Sound", by Sherman and Butler.
You can take a quick peek at them at amazon.
I know a little something about the physics of sound propagation in
different media.
My original question was about building a sine wave oscillator, which
has been answered, and I wish to thank everyone who replied. I know
what I am up against as far as sending sound through the ocean. I am
trying to design with those principles in mind, hence, the reason I
wanted to maximize the output from my multiplier.
Electronics has been a hobby for me, so that is why I come here and
ask questions on occasion. Most of the time, I just lurk and learn.
Oh, and screw up algebra.
Thanks again to all who replied. I believe I can make my way from
here.
Joe
