Maxouishere
- Dec 29, 2021
- 78
- Joined
- Dec 29, 2021
- Messages
- 78
Hello.
I am using Arduino UNO for a hobby project. I send 5V,1000hz signal through its PWM pin to XL6009E1 voltage regulator to boost the output voltage from 5V to 12-35V. It sends a signal for 2sec and waits for 3sec before sending the signal again. The problem is this voltage regulator has fixed 400KHz Switching Frequency whereas I need 1KHz. Other problem is when I measure the amps by using multimeter, It shows that I have 0.08A whereas I need 0.2-0.8A. How can I manipulate these values without going out of 12-35V range? I just ordered bunch of transistors and capacitors with different specs. I am planning to connect them one by one and measuring the values.
My problem is probably easy to solve but please keep in mind that I have very little understanding of how circuits work.
Thanks in advance!
Thanks in advance!
