Hello
I want to build a light for my bicycle, all from salvaged components.
I have a DC motor that I want to use as the generator, and some LEDs mounted on a PCB with a resistor, accepting 5V.
I want the circuit very simple, and I have come up with the circuit in the attached image.
As the motor might put out more than 5V I put a Zener (5.1V) in backwards voltage.
The 1N4004 is there in case the wheel rotates in reverse, in which case the voltage will be reversed. since I don't expect this to happen much, I don't think a rectifier bridge is necessary.
the cap is actually 3 electrolytic caps connected in parallel. they are rated 25V, two at 1000uF and one at 2200uF.
my questions are - does the circuit look OK?
should I incorporate a resistor in series with the zener?
is the zener enough protection from voltage surge? keep in mind that I will only connect LEDs to it, and the caps are rated at 25V, so they can probably take some extra.
thanks a lot!
thanks a lot!
