D
Damn Dan
I've been working on a project that would recharge the battery of my Honda
Insight (a hybrid vehicle) while I'm parked at work using a solar panel.
The Insight's battery pack averages around 165V during usage. Currently I
have the solar panel constantly charging a 12V battery with an appropriate
charge controller. The battery is then connected to a 12Vdc to 120Vac
inverter, which is connected to a 120Vac to 220Vac converter, which is in
turn rectified to 220Vdc. I actually only get 200Vdc in the end, I guess
just due to inefficiencies.
I'm trying to design a current limiter that would only allow as much power
into the 165V battery as is coming in from the solar panel. The panel is
80W, so after it's been stepped up to 200V, the output current is 0.4Amps
(200V * .4A = 80W). Thus, I want to implement a current limiter that will
only allow 0.4A into the 165V battery.
The main issue I'm dealing with right now is understanding how two power
sources interact with each other in the same circuit. Specifically, I have
a 200V source charging a 165V battery with 0.4Ohms internal resistance. So
is that exactly equivelent to setting up a circuit with a 35V source
(200V-165V = 35V) and a 0.4Ohm resistor? I set that circuit up in PSpice,
but it doesn't seem to account for the two DC sources interacting with each
other. Any thoughts?
