DarkMatter
A 12 V Nicad and a 12V Lead Acid can be charged in parallel?
Yes, if the charging voltage is correct, and the current is correctly
limited to the NiCad.
The reason a NiCad and a lead acid cannot be charged together would
be charging rate.
A lead acid battery can handle surges, and fast charge rates. The
NiCad has to be charged slowly to keep internal heating to a minimum
acceptable value.
This means things would have to be constantly monitored, and fully
charged units be removed at the appropriate times
No battery charging system can just be all balls constant voltage
sources.
So, yeah, Mr. Extreme case retard, they CAN be if monitored, and
current limited properly.
The scenario being discussed, however IS different.
YOU obviously didn't grasp much at all of the original post, boy.
