Basics of IF and Else statements (Arduino)
Stoneww
Apr 18, 2017
42
Apr 18, 2017
42
void setup() {
pinMode(10, OUTPUT);
pinMode(2, OUTPUT);
pinMode(12, INPUT);
pinMode(A0, INPUT);
void loop() {
analogWrite(10, analogRead(A0)/4);
if (12==HIGH)
digitalWrite(2, HIGH);
else
digitalWrite(2, LOW);
So this is my code. I want 2 to be the same logic as pin 12. So if pin 12 is logic 1 then pin 2 should be logic 1 and if pin 12 is logic 0 then pin 2 should be logic 0.
This doesn't work... I'd appreciate if someone could tell me where I'm going wrong with the code, I can't seem to find any similar examples. Thank you
Harald Kapp
13,745
13,745
if (12==HIGH)
This statement doesn't look for the state of pin 12, as you expect. Rather it compares the value 12 with the logical value HIGH.
You need to read from the pin like this:
Code:
if (DigitalRead(12) == HIGH) then
Stoneww
Apr 18, 2017
42
Apr 18, 2017
42
Code:
Thank you so much :):)
