The Chop mode and Alt Mode on a analog O-scope is ment to display 2 signals at once and to measure the time difference between them
When using chop mode or Alt mode , the frequency has to be the SAME frequency?
What do u guys use the chop mode and Alt mode for?
At work when measuring Logic signals , the square waveforms look like the square are dirty signals and the lines of the transitions and alternation and edges are not straight
Why don't they look like straight lines on the logic waveforms?
When Measuring 20uS pulse waveforms on my oscilloscope when i zoom in and stretch out , it changes a pulse waveform either to a cone shape or adds a rise time and fall time to a square waveform, The tech says its a o-scope resolution problem
Another Problem I'm having on the O-scope is that i have to measure 20uS pulse waveforms but that are at different times in the time line like 20mS, 50mS , 80mS, 100mS, 300mS , 500mS in the time line
How can you measure a 20uS pulse waveform when its 500mS in the timeline?
If you use a storage O-scope and zoom in on the 20uS pulse waveform and set the O-scope to 50uS timebase , it will stretch out the pulse waveform or make it in to a cone shape triangle, so there is no way I can measure the Pulse Width when it does this
How would u measure the Pulse Width when there is a Pulses at 20uS , going down a time line from zero to 500mS?
