Audio splitter With Amplification
LightShow
Jun 9, 2016
111
Jun 9, 2016
111
Hey all
I have This small audio splitter which takes one single 3.5mm audio jack and then splits it out 5 ways allthough the output sound is low when all are connected at once.
i wanted to know if it would be possible to make a 5 way splitter with amplification so that all 5 outputs have a strong audio signal output from the device which preferably should be battery powered..
Let me Know Your thoughts
Regards, lightshow
https://www.amazon.com/6-Way-Stereo-Headset-Splitter-Headphones/dp/B00DQUU8T4
14,268
14,268
hi ya :)
what is the audio source ?
a phone or other MP3 player ?
is there still not enough volume even if the source volume is turned up ?
LightShow
Jun 9, 2016
111
Jun 9, 2016
111
hi ya :)
the way i use this setup is usually with a laptop or phone connected to multiple headphones or speakers..
for small parties we connect 5 UE BOOM's to the splitter and play music that way allthough the volume difference is significant
LightShow
Jun 9, 2016
111
Jun 9, 2016
111
hi ya :)
at full volume the splitter sounds like its running at around 60% of volume
14,268
14,268
OK
Im thinking a small audio amp between the source and the splitter .. something based around an LM386 or similar
maybe eBay has ready made booster amps, try some searching :)
14,268
14,268
LightShow
Jun 9, 2016
111
Jun 9, 2016
111
we need to keep your battery supply/portability in mind for anything suggested :)
i dont have a problem using one for each channel :p allthough im hoping it will all work via something like a 9v battery
14,268
14,268
will require something with a bit more guts than one of those. The 9V PP3 is for very low power consumption uses
depending on how long you want it to run for, either a NiCd, NiMH or LiPO types will be required
LightShow
Jun 9, 2016
111
Jun 9, 2016
111
Something rechargeable would be better so maybe a LiPO Would suffice..
What Current\Voltage Should i be looking for?
A couple of comments.
LM386 is very old technology and not very efficient. There are 3W class D stereo amplifier available on EBay for a couple of bucks. This would be much better for your application. It would last twice as long on batteries, for example.
Also, if you are connecting 5 pairs of headphones in parallel, this may lower the impedance enough to give the amplifier problems. Assuming 32Ω, which is typical of earbuds, the impedance would be 6.4Ω which should be fine for the class D amps I am recommending. If the earphones are 8Ω, you cannot parallel 5 of them.
And one more thing. The LM386 has a minimum gain of 20dB. This is too high and will be driven into distortion by a headphone output. You would need to reduce the level with a divider. (this might also apply to the class D amps, not sure that gain they have).
IXP
14,268
14,268
true
as I said there I wasn't sure what else is available
got an example, please, so we are all on the same page
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
Your music source is designed to drive one pair of headphones, 5 in parallel overloads it which reduces the volume and causes distortion. You need to boost the current, not the voltage.
The ebay LM386 amplifier has a voltage gain of 200 (!) which is way too high. If you fiddle with its tiny parts then you can reduce its gain, but its minimum allowed gain is 9 which is still too high..
The ebay class-D amplifier also has too much voltage gain.
Since the amplifiers amplify their noise (hiss) then if you reduce the input level the hiss will be annoying.
14,268
14,268
cool, but I prefer this variation ... has a built in stereo volume control
http://www.ebay.com/itm/PAM8403-5V-...id=100623&rk=4&rkt=6&mehot=ag&sd=272315746788
using the suggested amplifier above I will need to regulate voltage for anything above 5v?
yes you will
Operating voltage: 2.5V-5.5V
with 5.5V being the absolute max
you could look at using say 3 x 1.2V AA rechargables or maybe a 3.6V LiPO style with appropriate charger
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
The PAM8403 amplifier has bridged outputs so the "splitter" cannot be used because it will short circuit the half of the bridged output of one channel to half of the bridged output of the other channel.
Also, the PAM8203 amplifier has a gain of 24dB (16 times) which is too high unless you turn down its volume control a lot.
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
For headphones you should forget about using this amplifier.
Note:
Left and right channel output of the "negative" can not be together, otherwise it will burn IC, and speaker(load) should be connected before power on.
