Wires in a 3.5mm audio splitter
Discussion in 'Audio' started by jcvamp, Nov 17, 2015.
  1. Martaine2005
    Martaine2005
    2,575
    695
    May 12, 2015
    Me neither....If he had the instructions...as we say RTFM...
    Martin
  2. jcvamp
    jcvamp
    6
    Nov 17, 2015
    I didn't have instructions. I was trying to connect an amplifier board to the Raspberry Pi. I decided to solder the wires of an audio jack to the amplifier board, and then plug the jack into the 4-pole AV port of the Raspberry Pi. The issue I faced was determining which wires to use from the audio cable.
    I sought help here, and used your suggestion about using my multimeter to trace the wires. Unfortunately, after soldering the audio jack to the amplifier board, I was unable to get the speaker to output sound. I decided to see if it was possible to solder directly to the Raspberry Pi, and I found some instructions that showed me how.
