[email protected] wrote in @l70g2000cwa.googlegroups.com:
I am trying to make a PS-ATX-300S computer power supply come on to
power a car radio. I only need 2 12V leads and a -12V ground. Any
suggestions would be appreciated.
You sure about that? A car radio needs 12v, thats 12v+ and Ground not 12v-.
If you use 12v+ and 12v- you'll have 24v and you'll blow the radio. I think
you'll find using the yellow 12v+ and black ground from the ATX drive
connectors will give you the 12v you need.
Also the atx supply will provide a lot of amps at the 12v+ but the 12v- is
usually rated at less than one amp. try drawing more than that and the atx
supply will not like it..
