N
Nemo
I've got some very low level signals at up to 150kHz going down some
RG174 cable, which is pretty well shielded (85% coverage or more if I
recall the cable spec correctly). It struck me I might be able to reduce
noise further by adding a ferrite tube to the cable, which I've often
done with unshielded wires. However, when asked to explain this to a
colleague, I found I didn't know as much as I thought I did, and
couldn't convey how ferrites act as common mode chokes to him.
On thinking about how coax works, with the inner and outer current
cancelling each others' fields, I wondered if adding a ferrite might
actually *disrupt* the flow of current round the coax and make
interference worse rather than better - i.e. by increasing impedance to
high frequency currents so that the coax shield was poorer at high
frequency. And reading further about ferrite cable shields, they seem to
be discussed mainly in terms of reducing emissions rather than reducing
incoming interference. Another thing that makes me wonder if mixing
ferrites and coax is bad is: articles discussing coax as a solution to
interference make no reference to ferrite cores. I am now rather
confused on the issue. If anyone has any experience in combining
ferrites and coax I'd appreciate advice on this matter.
