Adding motor into simple circuit
Happinessishorizontal
Jul 1, 2018
8
Jul 1, 2018
8
Hello. Im New to electronics of any kind, so any help appreciated. IV made the circuit in the diagram and it works.. However I want to add a motor, triggering when the switch operates.
https://drive.google.com/file/d/1NItqxFa9Ik0oeQqjqdOPX2vHjqz7oNaW/view?usp=drivesdk
If I do this now it basically sucks all the power and the sound module doesn't run.. Which makes sense..
Any suggestions on how I could achieve this?
Thanks Steve
Jul 1, 2018
8
Jul 1, 2018
8
Here we go. Sorry about that. I couldn't get an url on my phone earlier.
Thanks for the replies so far
AnalogKid
Jun 10, 2015
2,896
Jun 10, 2015
2,896
Bigger batteries, or separate batteries for the motor and a second reed switch close enough to the first one to be operated by the same magnet. What information do you have about the motor - voltage, current, power, etc?
ak
Jul 1, 2018
8
Jul 1, 2018
8
I had thought of doing it with a second reed but not sure if it would work in this application.
The magnet will be attached to the minute hand if a quartz clock and would be used to switch on the sound and motor at the same time.. So not sure how well they would sync.. I'll give it a go though.
I'm not clued up on electronics, so all I can tell you is the motor is a geared one that can operate between 3 and 12v. I was aiming to run it at about 3v DC
Cheers for the reply
6,943
6,943
Reed switches are typically used as sensors and at 500mA max not designed to switch motors.
Use a relay, transistor or mosfet to drive the motor.
You can still use the reed switch to activate the motor driver.
What is the battery bank made up from?
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
Obviously, the battery cannot supply enough current to operate the motor plus the sound module. Use a more powerful battery.
American and European batteries are powerful, Chinese batteries are garbage. Carbon-zinc and Super Heavy Duty batteries are also garbage.
AAA cells produce very low current for a short time.
AA cells produce low current for a longer time.
C and D cells produce much more current for a longer time but some D cells have a smaller C cell inside.
The motor you are using has a minimum voltage of 3V but your 4.5V battery quickly drops to less than 3V.
Jul 1, 2018
8
Jul 1, 2018
8
Thanks everyone.
Ok - sound module is an ISD1820
https://www.ebay.co.uk/itm/ISD1820-...535768?hash=item3d1bddf3d8:g:E~wAAOSw705Z4fAf
Batterywise I can use anything I can fit in my clock design.. As long as they're generally available.
I could do it with 2 switches as mentioned prior. I looked at those ir proximity switches, that I think could be used to detect the minute hand..?..
I haven't used them before though, so anyone know if that's feasible?
Cheers
Jul 1, 2018
8
Jul 1, 2018
8
Hi again
I have just been trying to work out those optical switches
Do they simply work as a switch? ie you power accordingly and when they detect a reflection from a mirror for e.g. they put the power through to whatever is connected?
Im looking at the
Vishay TCRT5000 Optical Switch Phototransistor Output
https://rapidonline.com/vishay-tcrt5000-optical-switch-phototransistor-output-60-8260
If this was the case it would be ideal in my application, however my gut tells be they're more complex..
No, the internal resistance is higher on the smaller cells, so they cannot deliver as much current.
If you short circuit (not recommended) a D cell might provide 10 Amps, whereas an AAA would not even reach 1Amp.
Jul 1, 2018
8
Jul 1, 2018
8
Thanks Bob.
Im at the level when i haven't digested Amps, voltage etc.. and their meaning..!
So if im running a motor at 3v with a light load on the motor, wanting the best battery life, am I better on Ds or AAAs?
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
A large battery cell can provide much more current than a small battery cell. The current drawn by your motor overloaded your battery because the motor is too powerful using too much current that your battery could provide, because the battery was too old or poor quality, or because the battery was too small.
A tiny button battery cell also produces 1.5V, the same voltage as a huge and heavy D cell. But the tiny cell cannot produce much current.
The datasheet of an Energizer AAA alkaline battery cell shows that it can provide a current of 0.5A for a little less than one hour but then the voltage has dropped to 0.8V. It cannot produce much more current than 0.5A.
Their D cell can provide a current of 0.5A for 18 hours, or 1A for 8 hours or 5A for maybe a little more than one hour.
Your motor must have a datasheet that says how much current it uses at 3V when it is working harder that yours will be working.
D's will give you about 12 times as much run time as AAA, if the AAAs could do the job, which they apparently cannot.
13,748
13,748
Not likely, see this discussion.
A photoelectric reflex sensor would work.
That is too little information. We need at least the current consumption of the motor when running from 3 V.
If the current consumption is too much for the battery, it will not help to have 2 separate switches as the voltage drop from the motor's current draw will still stop the sound module from operating. You need to make sure that the battery is able to supply enough current for both motor and sound module at the same time.
Even so, chances are that electrical noise from the motor will interfere with the sound module's operation. A filter between the battery and the sound module may help. Use an RC low pass filter made from a small resistor (e.g. 10 Ω) and a large capacitor (e.g. 470 µF).
darren adcock
Sep 26, 2016
463
Sep 26, 2016
463
If you aren't too attached to the motor you have already it could be useful to offer up some options you find on the internet that are similar. We can then get an idea of what rpm you require, torque needed (I'm assuming not much, but then we haven't seen your mechanism)... this way we can look at the spec sheet that goes with the motor and work out what is best for you. In the mean time, best of luck.
