T
Tomislav Jurkic
I have a problem with 6-pin video cable used on Leadtek Winfast 2000XP
TV card. So, if any of you with experience in this field can help ,e. I
will be glad and more than happy.
This Leadtek Winfast TV card has a joined S-video/composite video input,
which results in 6-pin input jack, the same as PS/2 connector. The
problem is that I do not have adapter for this 6-pin connector, and I am
not able to connect any S-video (4 pin) or composite signal to this
card. On the internet I have found that 6-pin connector is used in such
a way that 4 pins are connected to S-video, and 2 pins to RCA (composite).
My question is how to connect those pins in such a way to make adapter
RCA -> 6-pin (PS/2) as I have CCD camera with composite (RCA) output
jack, and I need the video signal to be fed to my PC through this TV card.
In the local shop with electronic equipment, the guy told me that I have
to use a condenser of around pF when connecting pins from 6-pin video to
RCA. I don't have any idea why I should put condenser in the circuit,
and I don't know if I need it at all. Can you help in that matter? Do I
really need condenser, or I can easili just connect pins from 6-pin
video to RCA?
Thank you for your help.
Tomislav Jurkic
video to RCA?
Tomislav Jurkic
