PLCC 84 pin prototype adapter
Discussion in 'Electronic Design' started by joseph, Jan 12, 2008.
  1. joseph
    joseph Guest
    I am prototyping a 84 pin CPLD. I need a prototyping board which can
    convert from the PLCC package and individual leads. I have one which
    converts from PLCC to DIL but it is too large for my needs. I have
    seen boards which convert from PLCC to protoboard.
    Any ideas on how to proceed?
    Thanks a lot
    Joseph
  2. Andrew Holme
    Andrew Holme Guest
    PLCC84 sockets have pins on a 0.1" matrix. How about mounting a socket on a
    piece of plain 0.1" matrix board?
  3. Tony Burch
    Tony Burch Guest
    Hi Joseph,
    The Schmartboard ones look like they could meet your requirements
    http://www.schmartboard.com/index.asp?page=products_plcc&id=85
    Schmartboard seem like an awesome company!
    I'm not sure how Schmartboard recommend that you solder those, but if I was
    going to do it I would definitely use a technique similar to the "Solder a
    QFP" free videos at my site http://SuperSolderingSecrets.com
    I've soldered may PLCCs this way. Solder joints for PLCCs use alot of
    solder, so load up the tip of the iron fairly generously with solder before
    dragging across the fluxed up pins.
    By the way, what CPLD are you using? Xilinx XC9500 / XC9500XL?
    Kind regards,
    Anthony Burch http://SuperSolderingSecrets.com
  4. joseph
    joseph Guest
    Hi Anhtony,
    I am using the Xilinx XC9500. They have 5V logic input/output and
    quite versatile. I have the ordered the through PLCC. Does
    Schmartboard work with these as well?
    Regards
    Joseph
  5. Tony Burch
    Tony Burch Guest
    Hi Joseph,
    I believe you could use Schmartboard with XC9500. As Andrew also suggested
    the PLCC84 sockets are a good way to go. If you have already orered the
    through-hole PLCC sockets, then I think you will be fine with that.
    Some time ago I prototyped an XC9500 (XC9536 and XC9572) in a PC44 package.
    I used a PLCC44 through-hole socket pushed into an array of snap-off wire
    wrap socket pins. The wire wrap pins were pushed into veroboard / matrix
    board. Then I wirewrapped the circuit...worked nicely. However, I'm not
    necessarily recommending wirewrap - it was just something I did at the time.
    If you put your PLCC socket into some vero stripboard, on the bottom of the
    stripboard you can remove the copper around every second pin on the strip
    rows, so that your pins are not shorted. Use a spot-face cutter (or a
    quarter inch drill bit) just rotated on the stripboard holes. Of course, do
    that before you insert & solder the PLCC socket to the stripboard:)
    Another alternative to wiring up is to put the device in the PLCC socket,
    then mount it upside down on top of some veroboard. Maybe just held in place
    with a tiny little blob of silicon sealant right in the centre of the chip.
    Then you can wire out from the bottom of the socket to the veroboard. This
    is kind of the "dead bug" technique where the chip is mounted upside down on
    the PCB & looks like a dead bug with it's legs in the air:)
    Don't forget to put your ceramic decoupling capacitors as close to the
    power/ground pins as possible.
    Kind regards,
