Hello
I will borrow a Sencore SC61 scope to a friend who do not use it, maby I
will buy it anyway since it is doing nothing in his basement.
Btw, what would be T.BAL , F.BAL, TEOF ?
Thank for your help
Bye
Gaetan
T.B(AL) is tracking balance. Sometimes also known as E-F BAL (named for the
designations of the two photodiodes, "E" and "F" in the pickup, which are
responsible for generating the tracking control signal). It is required in
order to remove unwanted positional offsets of the lens which would
otherwise be caused by imbalances in the tracking servo photodiodes in the
pickup, and the following opamp in the tracking servo processor.
F.B(AL) is focus balance. Does the same for the focus servo circuitry as
TBAL does for the tracking.
TE(OF) is tracking error offset. Allows the electrical zero point of the
tracking servo to be set to match the lens suspension mechanical zero. It is
needed to offset mechanical errors in the construction of the laser, and
electrical servo errors which may creep in as a result of imperfect opamps
etc in the servo amplifier.
FE(OF) would be the same thing for the focus servo, and is needed to correct
for such things as an error in the turntable height, and similar servo
electrical errors.
You may find a pot called PLL on some players. The setting of this is
*extremely* critical to data recovery from the disc, and requires an
accurate frequency counter to set it up. NEVER adjust this pot randomly,
even if you think that you have marked its original position perfectly.
It is rare to find any of these adjustments present, in modern players. The
servo processor ICs are these days capable of performing an analysis of the
signal, and introducing and storing appropriate correctional offsets.
Other pots which may also be encountered are T.G(AIN) and F.G(AIN). These
set the operational gains of the tracking and focus servo loops. They are
often to still be found in modern players. Adjusting these up slightly, can
often improve a player with marginal performance, but if set too high,
particularly in the case of the focus servo, will result in the lens making
a mechanical 'hissing' noise, particularly on a marked or scuffed disc.
Finally, there is always a pot on the laser which sets its output power.
With a few notable exceptions such as Pioneer, this pot is sealed and MUST
NOT be adjusted. Even a small overdrive of the laser diode, can result in
its partial, or even complete destruction.
Arfa
