"the term Back EMF' is also self describing.. a back flow
of electro motive force though the feeders from the motor.
your complete unawareness of this very commonly faced and
studied situation defines your level of insight in the
electrical engineering field.
Back EMF is a voltage.
Correct. But missing the next step...this back emf goes back
into the power grid ..and that increases with phase angle
distortions etc. You think there is some magic door at the
motor leads that stop these effects? read up bud.
Back EMF is a voltage. It opposes the terminal voltage, but it doesn't go
anywhere.
But under steady
state conditions,
ah now you are getting a little brigher ...you have covered
your ass, albeit a little late and issued an exception...in
your last sentence... 'under steady state conditions'... most
industrial motors operate in anything but steady state
conditions..with line voltage constantly varying... and low
voltage an absolutely cronic problem in hot weather in most
parts of the country... so much for 'steady state conditions'
Wrong answer. By steady state I mean the power system is supplying power to
the motor which is turning a load as opposed to the power system having a
fault and the motor acting as a generator supplying fault current.
correct. Otherwise described as 'back emf'
Wrong, back emf is a voltage.
And since back emf is a voltage by definition, are
you saying a
look... really you must get a grip here...voltage alone as
you surely must know is not particularly relevant unless there
is amperage involved..so the back EMF is NOT just voltage as
you state...it is as its own term says Electro Motive
Force...and that is comprised of both voltage, and amperage
and in an AC system, wave function. Force is an energy
function... the number of electrons and the voltage applied
defines the net 'force'... thus the term EMF.
Now you are just being annoying. Back EMF, or counter EMF, as defined by
IEEE STD 100:
"The effective electromotive force within the system that opposes the
passage of current in a specified direction."
Now we look up EMF:
"Electromotive Force. See Voltage"
What was that? Oh no, it really is a voltage. Just as anyone familiar with
Faradays Law would know.
For your reference, this was out of IEEE STD 100-1988 but I doubt the
definition has changed since then.
Other references that will help you understand exactly what emf is:
"Electromagnetics", Third Edition, J. D. Krauss, McGraw Hill, 1984, pages
124-128.
"A Programmed Review for Electrical Engineering", Second Edition, J. H.
Bentley, K. M Hess, Van Nostrand Reinhold Company, 1984, page 91. (nice
equation for emf, answer is in volts...imagine that)
"Electric Machinery", Fourth Edition, A. E. Fitzgerald, C. Kingsley, S. D.
Umans, McGraw Hill, 1983, pages 151-152. (Very nice explanation. They even
use the term "speed voltage" to try to give an visual of what EMF is).
"Electric Machinery", Fifth Edition, A. E. Fitzgerald, C. Kingsley, S. D.
Umans, McGraw Hill, 1990, page 10. ( very nice illustration and discussion
of emf..again as in induced voltage).
"Standard Handbook for Electric Engineers", 12th Edition, D. G. Fink, H. W.
Beaty, McGraw Hill, 1987, page 8.19. (nice formula for calculating emf.
Sadly, for you at least, the answer is in volts).
"Electrical Machinery", F. A. Annett, McGraw Hill, 1938, pages 119-137. (
an old book but a great explanation of how motors work. It is particularly
good for people without engineering degrees since it uses some very nice
analogies...you should like this one.)
These are just some of the books that I have in my office. I could come up
with dozens more if I walked down the hall to our library.
You should know enough to address EMF issues in its proper
context but obviously you do not. Thats revealing. I suggest
you avail yourself of the nearly countless books and articles
on these very very common issues. Its not rocket science...
I think you would be well served to read the above mentioned texts.
Even your own reference calls it a voltage. Sad really.
You have shot your credibility with your posts. You have used incorrect
terminology in nearly every post in this thread. When this was pointed out
to you, you attacked those who knew what they were talking about. I suggest
you reference a few text books before posting again. This may save some
embarrassment on your part.
Charles Perry P.E.
