D
daestrom
They have provided references to several university level texts, they have aIf you take two half wits and multiply them you do not get
unity.... but 0.25....even if you add two half wits you dont
get unity even though the math could be seen as correct.....
Claiming PhD status just makes it worse. It also wouldnt be
the first time ive seen the less utterly brilliant working for
a power company.
You are asserting that a corporate postion implies competence?
I dont think you are actually...but thats how it comes off.
particularly high level of education in the arena of electrical machinery
and power systems. And their explanations are in align with many references
found in university level texts and on-line web references. Your theory,
however is *not* supported by the few web links you've given, is *not* found
in any university text and does *not* fit the observable facts.
You have claimed that your explanations are 'well known in the industry'.
But people like Charles, Don and myself are members of that industry. And
have each of us been in that industry for many years. We have separately
worked in the field of power systems and large scale electrical machinery
for quite some time, yet we haven't heard of it. You may claim we're
ignorant, but if we haven't heard of it, so much for your assertion that 'it
is well known in the industry.'
On the voltage/ force issue... those are similar but not
identical... that is the root of our little disagreement here.
...Force = Mass x Acceleration.., forever ... in physics..and
the study of electricity and its current is part of
physics....
Force = mass x acceleration is the physics of how a force interacts with
any mass. It explains how a net force on a given mass will accelerate it.
If a given mass is observed to be accelerating, the formula can be used to
calculate what net force must be acting on it.
But it is *NOT* the only definitive explanation of 'force'. It *has* been
used as the definition of mass, which is also an interesting definition of
inertia.
Force = K * X
where K is a constant for a linear spring and X is the spring displacement
from its 'rest position' Hmmm, no 'mass' in this equation. Do compressed
springs not exert a force?? And don't go claiming that a massive spring
exerts more force than a small one. It can easily be demonstrated that the
force exerted is not always dependent on the mass of the spring.
Force = K * m1 *m2 / r^2
where K is the universal gravitational constant, m1 and m2 are the masses of
two bodies and r is the distance between the bodies. True, we have *two*
masses here, but no acceleration term at all.
Force = K * c1 *c2 / r^2
where K is the faraday constant, c1 and c2 are the net charges of two bodies
and r is the distance between the charges. No masses here. True, the
fundamental unit of charge (so far in physics) is found on an electron (that
has a mass). But the amount of force exerted by this is a function of the
*charge*. The electrostatic force on two different amounts of masses can be
the same if the *charge* on the two masses is the same.
Force = K * c * E
where E is the electric field strength acting on a unit charge. Again, the
force is a function on the amount of *charge* on the object, not the mass of
the object.
Force = K * B X V
where K is another constant, B is the magnetic field strength and V is the
velocity of a unit charge moving through the field. Here we must be careful
to use the 'cross product' of the two vectors.
Interestingly, the international definition of the fundamental unit of
Ampere uses 'force' in its definition....
"The ampere is that constant current which, if maintained in two straight
parallel conductors of infinite length, of negligible circular
cross-section, and placed 1 meter apart in vacuum, would produce between
these conductors a force equal to 2 x 10-7 newton per meter of length."
This is the one electrical quantity that is in the SI base units. From this
and the other base units, the derived SI units for electrical power,
voltage, magnetic field and many others are derived.
Taking the mass out of it as you have in some of your examples
...say for instance a generator not connected to a circuit
indeed leaves voltage live and mass static...but its still
mass.. the electrons availabe to move.. the force remains
potential.
A large motor generatiing back emf .. would generate more of
that in terms of voltage and amperage than a smaller motor
obviously.... so this EMF term does have a variable other then
voltage...thats quite obvious in this example... or all EMF
would be the same in magnitude..and it isnt.
Actually, a 1 hp motor, or a 100 hp motor generate almost the same amount of
'back emf' when running unloaded. They both generate 'back emf' that is
*almost* equal to the line voltage applied ('almost' because they both have
losses). And since 'back emf' is a voltage, *not* a current (as so many
folks have tried repeatedly to explain to you), it is pretty much
independent of motor size if the applied voltage is the same.
And because the premise of your statement is flawed, (that larger motors
generate more 'back emf' than smaller ones), the rest of your conclusion is
flawed as well.
A large motor, say 1000 hp is going to kick back 100.000 times
the net force (EMF), as a say a tiny 1/100 hp motor... that
should be implicity obvious. Is it obvious to you?
No. A 1000 hp motor designed to run on a 4160V line, running unloaded, will
be generating an internal voltage very close to 4160V. Similarly, a 1 hp
motor designed to run on a 4160V line running unloaded will be generating an
internal voltage very, very close to 4160V. If what you say were true, the
1hp motor would be generating an internal voltage of only 4.160V. And if
*that* were true, what limits the current flow from the 4160V to 4.160V in
the 1 hp case? Winding resistance? The winding resistance of such a motor
would be much less than 1 ohm, so Ohm's law would indicate the 1hp motor
draws 1000 times the current of the 1000 hp motor when they both run
unloaded. Isn't it obvious that that isn't true?
Do I need to prove that... ?
the *voltage of the emf will be the same under the same
conditions of course... but the net EMF... with the force term
used, will of course be dramatically greater with the huge
motor...roughly 100,000 times greater with the larger motor.
That of course is because of the huge mass differences between
the two motors.
You keep trying to separate the 'EMF' from 'voltage'. The term 'EMF' is an
achronism for voltage.
If you keep insisting that F=M*A is the only formula for a force and EMF is
dependent on mass, then how do you explain the operation of a DC machine
where the current is constant and there is no acceleration? By *your*
notions, the force in a DC machine is zero, regardless of its mass since the
current flow is constant and there is no acceleration. Let me guess,
because the rotor is spinning, all the electrons on the rotor are undergoing
acceleration??? That's a non-starter, it implies a large diameter rotor
with the same mass rotating the same speed as a smaller diameter rotor
generates a different amount of 'back emf'.
obviously then, not a straight Voltage =emf issue. emf
more closely relates to power when in motion..than merely the
voltage applied. Voltage remains constant regardless of
any motion or not...but the force varies... thus the term EMF.
Again, you keep coming up with some vague idea/definition of what 'emf' is,
when the rest of the world use to use the term for voltage. The rest of the
world agrees that 'emf' is an antiquated term for a voltage created by
electromagnetics. Yet you keep insisting it is F=M*A.
So far, you've said that this 'back emf' is a function of 1)machine mass, 2)
rotor speed, 3)hp rating. Have I left anything out, or is there some more
variables you want to throw in?
I think thats a fairly concise argument.
I don't. Study the equivalent circuit of a DC machine and you will find an
internal *voltage* generated that is proportional to field strength and
rotor speed. It is not described as a 'force' except in antiquated texts.
I have used the term counter EMF in the past also... but do
not equate it to 'back EMF' as you do... back EMF evolved I
believe to more clearly describe emf coming back out onto the
grid, slightly out of phase with incoming current.. and at a
different amplide, somewhat as AM and FM radio waves modulate
amplitude or frequency.... yet the same signal being carried
on a single antena.
Funny, I've seen the voltage at the terminals of many an AC motor on an
oscilloscope and never seen such 'emf coming back out onto the grid'.
(voltages measured line-line, line-neutral and current waveforms measured by
the voltage drop they create through precision resistors) I have seen
distortions in the supply voltage, but they only exist when a non-linear
load is connected. The distortions in voltage are easily explained by the
resistance/reactances of the supply and the non-linear currents caused by
non-linear loads. Power supplies with much lower impedances tend to have
much cleaner voltage waveforms than those with higher impedances.
Utilities *do* get concerned when one customer has severely non-linear
loads. Such a customer's severe high-harmonic *currents* cause high
harmonic voltage disturbances due to the utility equipment's
resistance/reactance. And if not controlled, the *voltage* disturbances
will affect other customers, whom the utility is obligated to supply power
to within the standards. Most utilities can compell such a customer to
correct the problem themselves, or charge them for having the utility
correct the problem so as not to affect other customers.
But this just doesn't happen with induction motors. In fact, *large*
induction motors, with many slotted windings draw almost perfect sinusoidal
currents and thus cause little or no voltage distortions in the utility
equipment's resistance/reactances.
But *your* theories would dictate that *large* induction motors generate
*more* of your mysterious 'emf' (it is clear now that your use of the term
is unique and *not* in compliance with any industry practice). So *large*
motors, because they have more mass, should generate more 'back emf' and
distort the grid voltage more? Yet experimental data, seen everyday doesn't
support that position. Large motors cause more of a voltage disturbance
,*when started*, but the disturbance quickly subsides as the motor reaches
normal speed.
As these emf influences leak back onto the power grid, they
create or constitute in themselves distortions in the electro
magnetic effects, reducing the efficiency of any connected
motors, designed of course to operate on clean power.
Simple fact is, voltage distortions on grid supplies are caused by distorted
*current* flow through utility equipment. The phenomenon can be fully
analyzed using conventional circuit theory by replacing the ideal voltage
source with a real one. Real world grid supply includes a variety of
resistances and reactances, whose voltage drops are dependent on the
currents flowing through them. I'm sure any university professor of power
EE would be happy to explain it to you (as Charles and Don have already).
I invite you then to review your materials on issues related
to some large industrial power users and their empact on the
quality of the power in the rest of the grid.. especially
customers farther from the generating source than the
industrial user in question.
Been there, done that. 'large industrial power users' come in all 'shapes
and sizes'. Arc furnaces (not induction or resistive ones, *arc*) are one
of the worst. They are a heavy load that is non-linear. High non-linear
currents cause non-linear voltage drops in utility equipment's
resistance/reactances. On the other hand, pumping stations whose major
loads are induction motors are pretty benign. Rolling mills are a bit of a
mix. Although the loads are induction motors that do not create a lot of
harmonic distortions, the loads are starting/stopping/reversing all the
time. Depending on their equipment, the constant starting/stopping of the
many motors cause periodic dips/surges in supply voltage. But these are
with a period of several seconds, not harmonics of the supply frequency. If
the rollers are controlled by solid-state drive (as many modern ones are),
the *drive system* can draw a lot of non-linear currents from the supply.
But if the drive is an older motor-generator setup to DC roller motors, the
harmonic distortions on the line are nil (but you still have the surges
caused by varying load).
Some customers have had problems when they installed versions of VVVF
control on some of their machinery. Although the connected motors worked
well because the VVVF drive has output capacitors, the VVVF drive's input
stage (typically a phase controlled AC-DC converter) would draw highly
non-linear currents from the supply. These currents would cause non-linear
voltage drops in the utility supply equipment and thus the voltage supplied
to other equipment is distorted. The severity of the problem is a
combination of the severity of the distortions created by the phase
controlled converter and the impedance of the supply. The 'fix' is to
filter the input to the phase controlled converter such that the supply line
'sees' less of the non-linear currents.
To summarize, when a large customer draws a high amount of non-linear
current from utility equipment, the resulting voltage drops created in that
utility's equipment will also be distorted. And yes, that can affect other
customers. But... 1) The distortion is easily analyzed by conventional
circuit analysis of the load current and supply resistances and reactances.
2) Induction motors are some of the *least* offensive loads in this regard
(electronic phase-controlled and arc-type loads are the worst). 3) The mass
of a motor has nothing to do with the amount of internal voltage developed.
4) 'back emf' is an antiquated term used to describe the internal voltage
developed in a spinning motor, nothing more (except in your very small
little world of one).
And to return to the original point of this thread for a moment, neither
voltage nor current distortions have any appreciable affect on the accuracy
of the standard household kwh meter. Although a voltage imbalance between
hot legs and the neutral can, as I recently learned from Dan Lanciani's
discussion.
daestrom
