Tim Burchfield
- Sep 26, 2017
- 8
- Joined
- Sep 26, 2017
- Messages
- 8
Hi. Brand new here so excuse me if I don't follow protocol. I have LED turn signals in my old English sports car powered by an electronic flasher. The P terminal on the flasher is supposed to power the turn signal indicator. My car did not come with a turn signal indicator light so I want to add a buzzer to let me know when the turn signals are on. I installed the buzzer described below with the power from the p terminal on the flasher and the ground to the car body. The buzzer works great. But when the turn signal switch shuts off the blinker stops but the buzzer continues for a few seconds ending in a drawn out pitiful squeal. I'm guessing that there is some power still in the flasher when the turn signal switch is turned off. Can anyone suggest something to stop the buzzer form continuing after the power to the flasher is cut? The car is a 12 volt negative ground system.
Tim
Tim
