Recently i've built a couple of voltage regulator transistor emitter follower circuits, using a single TIP2955, and two TIP2955 transistors. Curiosity has led me to a more powerful transistor.
At this stage i am unsure as its gain minimum is quoted at 1K or 1000mA, its power rating is a lot more than the TIP2955 which i have had really good results with building these two 12 volt power supplys.
The transistor i am looking at, or hoping i can use is the following: Type MJ11015 PNP, VCB VMAX 120, IC mA MAX 30, PTOT mA MAX 200W, HFE MIN IC mA MAX 1K@20A, pin out is quoted as 23A epitaxial TO3 package. I was hoping some one could help me through pitfalls if any of using this transistor, i have posted the schematic below. Where TIP2955 transistors are i wanted to use the following transistor above. i would be very grateful if anyone can help me with this. Many thanks.
