I think i got most of that, i will reread again, my memory is naff on med's (illness) but yes thank you Adam ! I will have to mock up a single transistor board version to try this. Really i might just get a breadboard, its long overdue. Since then i have tried 4 x TIP2955's with very good results, although there is a modest voltage drop under load. 12.04 Volts no load, 50 watts load, 11.89 Volts, 100 watt load, 11.73 Volts. A15 Volts regulator could get round this, and drop it 1.5 Volts on the output.
This was already half constructed before i started on the MJ11015 darlingtons transistors. But i will make up another MJ11015 transistor circuit. When it did run with out the regulator doing battle with the transister, it ran very cool and minimal if no voltage drop, compared to the TIP2955's. Thanks again Adam your help is much appreciated !
Below 4 x TIP2955's
And running 100 watts, 2 x xbox psu's in series for the input, until i find a decent transformer.
