Tony said:
No, I think that circuit is wrong Fred. "200" is not the
thermoswitch, it is the ECU (Engine Control Unit?).
The gizmo labelled K is probably a solenoid that engages the a/c
compressor. It is powered via Relay156. The ECU (only) drives the
coil of 156, probably engaging/disengaging the a/c compressor
according to the required internal temperature setting. It is
also probable that the ECU does not engage the a/c compressor
unless the engine is running. Presumably the compressor puts a
significant load on the engine, so the second contact on 156
does a pre-emptive turnon of the radiator cooling fan.
But they also need normal temperature-sensed radiator cooling,
which is done by Relay396, whose contacts are in parallel
with 156.
The coil of 396 is not drawn on that Saab diagram, but has
been previously described as having the top end supplied with
+BATT (from terminal 30 of Relay156) and it's bottom end
going to ground via the thermoswitch. This is the only relay
that the thermoswitch drives.
The aircon was almost certainly an optional extra. If not
fitted, Relays 156 and 155 would not even be present, just
Relay 396.
Okay- after decoding one of the original posts it looks like this:
Please view in a fixed-width font such as Courier.
| (-)---(+) | | o | 169 |
--- | | | |/ | A/C DASH |
/// | BATT | | | o | SW |
| | | | 155
| | | 156 | 396| | | | | |
| 200 | | | | | | | | | | | | |
| | K) +-+ | | | K) o | | K) o |
+------+ | ) o o | | | ) / | | ) / |
| ---| | ) / / | | | ) o | | ) o |
| +-| | | o o | | | | | | | | | |
| T | | | | | | | | | | | | | | | |
| o | | +--------+------|----+ --- |
| o | | | 37 +-|-+ | 172
| | | |170 | A/C | o | 39 | MAIN
+------+ +----+ +------+ |/ | THERMO +------+
| | K | | FAN | | o | SW | FAN |
The ecu200 has to gnd the other end of 156-K since they say that's a 12V
Bosch. The a/c keeps main172 running continuously with the ac37 and
ac170 cycled by the tstat in ecu200- which also senses presence of the
12V through the pressure and temperature switches. thermo396 now
switches both fans on which was the main problem before where it only
turned on the a/c fan apparently- but they left that problem with 155-K
directly across the ac37 -causing the run-on. The simplest way to fix
the run-on is to add an el-cheapo relay XXX in parallel with 396 like shown:
| | | | 155
| | | 156 396| | XXX| | | | | | |
| 200 | | | | | | | | | | | | | | | | |
| | K) +-+ | | K) o | | K) o | | | K) o |
+------+ | ) o o | | ) / | | ) / | | | ) / |
| ---| | ) / / | | ) o | | ) o | | | ) o |
| +-| | | o o | | | | | | | | | | | | | |
| T | | | | | | | | | | | | | | | | | | | |
| o | | | +----------+ --- |
| o | | +---------|--+ | 172
| | | +-----+ | | | MAIN
+------+ | | 37 +-|-+ +------+
| |170 | A/C | o | 39 | FAN |
