Simon Girouard
- Nov 18, 2015
- 9
- Joined
- Nov 18, 2015
- Messages
- 9
Hello,
I want to add limit detection to a CNC and for this, I got proximity sensors. Here are the specs:
LJ12A3-4-Z/BY
Inductive type proximity switch with PNP Normally Open transistor switch. Output upon detection.
P/N: LJ12A3-4-Z/BY
Power: 6-36VDC
Output Current: 300mA
Detection Range: 4mm
Detected material: Iron/Steel alloys
Note: I already have the sensors and would like to use them and not have to buy something else if at all possible.
A way I saw to connect this was to apply a 12v source to the sensor and then have the sensor output signal go through a 7805 to the input pin of CNC board. But, this is good for 1 sensor.
How would I go about if I want to connect 2 sensors to the same input pin on my CNC board?
Thanks !
LJ12A3-4-Z/BY
P/N: LJ12A3-4-Z/BY
Power: 6-36VDC
Thanks !
