Sir Skip . . . . .
INITIALLY . . . . . with no power applied, check to see where your meters mechanical pointer setting is having
the meter pointer being positioned, as relevant as to how close it is initially being, to scale ZERO.
Then check out the meter amp and bridge circuitry for its +- 26V's supplies and derived -6 and 9V supplies.
Also check out how well and balanced the YELLOW squared electrolytics are holding up after being 50 years old.
This was a military / aerospace microfiche schematic, so I further magged it up enough to make every small
component marking readable.
Certainly beats the service manuals piecemeal schematic sheets, if you have to travel across sections.
Re . . . .REFERENCING:
73's de Edd
