No, not 'any' two tabs.
Measure the winding resistance to find the highest ohmic value. This will be the 'top' setting i.e. highest voltage on primary.
Using one of those two connections, measure the other connections. You should get a 'lower' resistance - not TOO low. If it's too low then use the 'other' connection you first identified.
What you're trying to do is measure the winding resistance to determine where the taps are.
T1---------------------T2-----T3-----T4-----T5
(N)--------------------(L)-----(L)-----(L)-----(L)
T1 would be the mains neutral (N) and T2-T5 the other taps - mains live will connect to any of the (L) points.
You do NOT want to connect mains neutral to any of the (L) points or you're applying mains straight across some very small portion of the primary and smoke will ensue.
The resistance from (N) to any (L) connection will be successively larger whilst the resistance between any two (L) connections will be 'small'.
