Help required on Logitech Z-2300 toroidal transformer #2
cero10
Oct 12, 2020
20
Oct 12, 2020
20
Hello guys. I want to power the z2300 with dc power but the 2x26.4V I have to feed the system after the rectifier is quite perplexing to me. Can someone tell me how can one or two DC adapter(s) handle this situation?
Moderators note : This post is moved from an old thread:
cero10
Oct 12, 2020
20
Oct 12, 2020
20
Can you be more specific, please? What is perplexing you?
First of all thanks for moving my reply. Is it possible to have a single Li-Ion battery pack act as a dual dc source in this manner?
or two separate Li-Ion battery packs:
Bluejets
Oct 5, 2014
6,937
Oct 5, 2014
6,937
Where does the transformer come in...??
Transformers work on ac, not dc.
I suspect you are talking about converters, not transformers so show your complete diagram.
Harald Kapp
13,738
13,738
If the single pack has a center tap, #1 would work. However, afaik cell packs are not meant to be used in this configuration. Therefore #2 is imho the better option.
cero10
Oct 12, 2020
20
Oct 12, 2020
20
Normally z2300 is supplied ac power from a dual transformer to a rectifier which then gives out +26.4V -26.4V and its keeping the ground from the transformer. I am just skipping the ac to dc part and I want to feed the z2300 dc power.
I was kind of expecting that...so in order to avoid any explosions I will go with #2. Thank you Harald for your advice.
Bluejets
Oct 5, 2014
6,937
Oct 5, 2014
6,937
As quoted earlier, I think you need to supply the complete diagram.
As it stands, if your original unit was a split supply, your #2 diagram will feed reverse polarity voltage to the normally split negative supply.
Shown attached is a standard arrangement from a transformer rectifier.
Harald Kapp
13,738
13,738
Right, I overlooked that detail. The batteries need to be placed as in the first diagram.
cero10
Oct 12, 2020
20
Oct 12, 2020
20
The z2300's original setup goes like this:
So from what I understand my two battery pack arrangement would be like this:
Bluejets
Oct 5, 2014
6,937
Oct 5, 2014
6,937
Where you are getting yourself all confused is the reference point for the voltage measurements which is normally ground.
Your photo 1 above shows as correct and although the photo 2 is exactly the same arrangement , you show voltages with reference to the negative supply.
It should be the same as photo 1.
Just watch your colour coding as it will end up with your having the lower converter getting connected a-about.
cero10
Oct 12, 2020
20
Oct 12, 2020
20
So is this the right way to illustrate it?
The rest of the connections are correct right?
Bluejets
Oct 5, 2014
6,937
Oct 5, 2014
6,937
Yes correct, although I would tend to use conventional colour coding for positive (at least part of) in the lower leg.
Others may disagree.
Harald Kapp
13,738
13,738
Two step-up converters will usually not work as you expect. In a step-up converter "-" in = "-" out thereby creating a short circuit for the lower converter:
bertus
Nov 8, 2019
3,330
Nov 8, 2019
3,330
Hello,
I would disconnect the two battery packs:
When the step up converters are not isolated you would get into trouble with your setup, as @Harald Kapp explained.
Bertus
cero10
Oct 12, 2020
20
Oct 12, 2020
20
Hello,
Bertus
I don't exactly understand how this works but if there no other detail overlooked, i guess I got my answer. thank you all guys.
