Hi, newb here and need help on a DC-DC boost converter circuit.
The input is a varying 11v-14v and I need a regulated 16v to 18v
output.
The switching frequency isn't critical, but the pulsed output current
needs to handle a peak of 15A.
Can anyone suggest a suitable IC and perhaps provide some insight into
a workable circuit?
How long are the pulses on the output? Can you use a large capacitor to
handle them so that the regulator only needs to provide the average
current?
At these currents, you may be better off with a PWM chip and power MOSFET.
Although it is more parts, it allows you to keep the 15A currents away
from the ground of the PWM chip.
Go get a copy of switcher cad from Linears web site. It is very helpful
for checking out your design before you commit it to real parts.
You need to perform some calculations:
We are boosting 11V to 18V so the inductor has 11V on it during the on
time and 7V during the off time.
For the smallest inductor, you want the current in the inductor to just
stop before the switch turns on again. This means that the peak
current must be:
Ip = 2 * 15A * (Ton + Toff)/Toff
But:
Ton = Toff * 11V / 7V
So:
Ip = 30A * (Toff * 11/7 + Toff)/Toff
Ip = 30A * 18/7 = 77A
This is likely to be the biggest problem in the whole design. You need an
inductor that is good for a fair bit more than 77A and is also good at the
switching frequency. I'd look for this from
www.rencousa.com or
www.coilcraft.com.
