12 MHz oscillator with a Voltage range 120V
Status
Not open for further replies.
kazemihossein33
May 12, 2018
May 12, 2018
Hello friends
I need a 12 MHz oscillator with a Voltage range of 120V
Preferably designed with cross coupling and non-integrated circuits
If I had a problem with my sentences, I'd like to apologize because I'm not English
Thank you for your guidance
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
Your english is quite good but you will need to give much more information.
A range of 120V could be 100V to 220V.
120V power input?
120V output?
power?
load?
frequency accuracy?
waveform?
kazemihossein33
May 12, 2018
May 12, 2018
120V power input?
120V output?
power?
load?
frequency accuracy?
waveform?
Thank you:)
The circuit information is as follows
Input Voltage Source: 120 V to 140 V DC
Output voltage: 120 V
Output current: 2A
Waveform: Sinusoidal
Schematic circuit
VVVVV
VVV
V
  • US6680657B2.pdf
Harald Kapp
13,752
13,752
Are you aware that at 120 V / 2 A you will generate heavy electromagnetic noise? What's the purpose of this oscillator? Is the purpose in line with the applicable regulations concerning short wave radio?
hevans1944
Hop - AC8NS
Jun 21, 2012
4,889
Jun 21, 2012
4,889
It has been more than a year since the first post on this thread. The OP disappeared the next day and has not been active here since then. So yet another "drive by" poster slinks back into their cave, unrewarded by an instant answer to their query...
Status
