B
BlueSpark
A friend has a Zenith model SLS2751Y with a very "soft" CRT. I
thought I would try a rejuvenation before telling him his best bet
would be to replace the set. Two hurdles exist. First, my
rejuvenator is over 20 years old, and surely would not list the CRT
number, and likely not to have a compatible adapter. However, I'm
willing to take one of the very old adapters and just crimp some pin
connectors onto the wires to make a "universal" adapter. But, I'll
still need the pin-outs and filament voltage for the CRT to connect
everything correctly. The second hurdle is the fact that the set is
mounted high up on a wall, and I'd like to avoid having to take it
down temporarily just to be able to remove the back to get the CRT
number.
If someone has a schematic for this set, and could post the pin-outs
and filament voltage, I would be most grateful. If that's too much
trouble, just the CRT number would at least allow me to try to find
the other info elsewhere, and avoid having to remove and reinstall the
set from its wall mount more than once.
Thanks in advance,
BlueSpark
number.
Thanks in advance,
BlueSpark
