D
Doc
I've been using a Digital8 camcorder to do some video capture using DV
format, this case capturing 8mm film, going in to the computer via Firewire.
I'm running into a problem.
I find that when I output through the camcorder directly to the capture
program without recording to tape first, I get an odd vertical banding
artifact when the resulting avi file is rendered for tape output or DVD. The
banding isn't extremely pronounced but it's there and enough to be
distracting when viewing. I'm basing this on what I see on a tv monitor,
i.e. outputting to the tv instead of to a VHS tape, or playing a test DVD
made from the file on a tv. However, this doesn't occur when recording to
tape first in the Digital8 format and then outputting that to the computer
and then rendering..
This banding also occurs when playing analog tapes through the Dig8
camcorder (this camcorder is backwards compatible) to the computer.
It doesn't occur when going through composite cables and capturing as an
mjpeg avi file instead of the DV format.
I thought it would be the same, but apparently there's some difference in
the DV output from the camcorder when doing it on the fly as opposed to
going from DV tape output.
Any ideas why this is happening, why it would be different and how it can
fixed? Capturing on the fly in the DV format is preferable for various
reasons. Time savings and the size of the resulting files among them.
Using WinXP Home, Sony TRV-240 Dig8 cam, Pinnacle Studio 9 as my capture
program. (Also tried using AMCap, with no difference in the results)
Thanks for all input.
