K
kony
Yes you do. The lowest rated supply I use for Athalon systems is 400
watts, and that is only with one HD.
Anymore and I go with a 500 watt.
Believe me if you really try and do any serious computing loads with
an under rated power supply you're asking for serious migraines.
It's true that an insufficient power supply can cause both
instability and eventual damage, but the typical Athlon
system does not need 400W, and there is almost no "PC"
system that needs 500W, even if the vast majority of the
current were concentrated on only the 5V or 12V rail.
With a typical PC, that being current-gen CPU, a couple hard
drives, budget/low-end video card, etc, 300W PSU in a good
name brand is sufficient. SFF systems demonstrate every day
that even a 180-250W PSU will run a modern built with enough
margin for another hard drive or two... but the PSU may need
replaced sooner.
Generics on the other hand, are a lottery. Their wattage
rating means almost nothing, they can only be assumed to be
somewhere inbetween 200W and 400W without further evidence.
