G
[email protected]
Hi:
What are the physical* reasons dial-up speeds cannot go above 56kbps?
One factor is that the phone line cuts of frequencies below 300 Hz and
above 3,000 Hz. What are the other physical causes of this limit?
Would this limit still exist if it weren't for the aforementioned
frequency-cutoffs?
bps = baud X number of bits per baud.
If only 1 baud is used, what is the maximum-bits-per-baud that can be
used on a phone line without the frequency of the analog electric
signal exceeding 3,000 Hz?
*NOTE: By "physical", I am referring to causes not associated with
legal regulations - such as limitations place by the FCC and
governments.
Radium
frequency-cutoffs?
governments.
Radium
