I
Ignoramus2330
You can consider this post to be venting, as such, possibly I do not
give enough information to solve my problem, and I am not trying to
avoid spending time with a multimeter.
So, I have this welder, with three phase transformer, where there are
two secondaries on every leg.
I have five contactors that switch from paralleling two secondaries on
every leg, and delta connecting them, for welding, to wiring them in
series Wye connected.
Put in the microcontroller, made some fixes regarding voltage feedback
and could run some stick electrode beads.
And then, after a short while, this thing stopped working because the
SCR firing board detected an error. As it turned out, there is
markedly lower voltage on one of the legs leading to the SCRs.
Voltage between legs 1 and 2: 68 volts, 1-3: 25 volts, 2-3: 25 volts.
So the SCR firing board detects imbalance and shuts down.
I measured input voltage from the phase converter, it was as perfect
as it could get, 248, 250 and 251 volts.
There is no electronics in the rewiring circuit, only contactors.
Contactors do engage, visibly, and there is no voltage difference
across any pair of contacts, so I think that they close properly.
This issue defies all explanations.
Very weird. Our neighbors will take our son along with their son to a
festival tonight, so I hope that I will have time to look at it.
i
i
