I am currently planning an LED panel for video/photography work. The plan is to connect 100 LEDs in parallel on a PCB. For the power source, I would ideally like to use a commercial powerbank so that I can easily replace the battery without needing a special type of battery. Also, a powerbank is easily recharged via USB, making it more portable.
The LEDs I will use have a max. forward voltage of 3.6V and a max. forward current of 20mA.
The plan is to connect the LEDs to the output of an LM2596 buck-converter (cheap adjustable chinese version) and to connect a a female micro-USB socket to the input of the buck-converter.
Since the buck-converter outputs between 1.3 and 35V, I would like to know how I could connect a potentiometer to it in order to limit the output voltage to the range 1.3V - 3.6V for dimming (without blowing the LEDs).
Also, can anybody point out something I may have overlooked when choosing a commercial "powerbank" as a power source? I would of course make sure to chose one with at least 2A output current and an over-discharge protection.
Thanks in advance.
Thanks in advance.
