B
BlueMoon Mac Resources
The above TV frequently has the picture collapse to the center one third of
the screen. Turning it off then back on sometimes cures it as does a sharp
rap to the side. It just started doing it a week ago but is getting
progressively more frequent.
I see a lot of chatter about the Thompson (RCA, GE, Proscan) tvs that have
the same problem caused by bad solder connections on the tuner shield
grounds. Is this tv prone to the same problem or are their other
possibilities?
I can solder, desolder, drain CRTs, work on static sensitive stuff (I repair
iMacs) so if it is simple I can probably repair it with some guidance.
Thanks to anyone who responds. adamAdam Tomash
BlueMoon Macintosh Resources
[email protected] (please remove yourpants)--
possibilities?
