T
Terry Casey
Robert said:He is looking for a *digital* computer, and it does not have to be
complicated or work with a lot of digits.
So..under 100 tubes, obviously diode logic will be required.
Wikipedia states "The Colossus machines were ... the world's first
programmable, digital, electronic, computing devices. They used vacuum
tubes (thermionic valves) to perform the calculations."
Note the words *DIGITAL ... COMPUTING DEVICES* in there!
I visited Bletchley Park some years ago, and saw the Colossus project in
its early stages. They started by replicating one 19" rack and, IIRC,
were using vertical chassis modules perhaps 4U high. These used Octal
valves, remember, so we're not talking any kind of miniaturisation here!
Presumably they were able to test each module independently after they'd
built it and one module or two may suit the OP's needs. (I wasn't REALLY
suggesting he'd want to build the whole machine!)
The OP was particularly insistent on needing detailed schematics - and
these most definitely exist for Colossus!
Could be worth contacting the NMOC to suggest exactly what he has in
mind - or perhaps they might be able to suggest what sort of thing he
could do with an existing module of a combination of modules as a
stand-alone unit?
Terry
